can any recommend an brand name hard drive that will work in a 556 or 557 ( not purchased from Toshiba) thanks in advance.
aftermarket hard drive for es 556 and 557
Re: aftermarket hard drive for es 556 and 557
Hytec Circuit Board, Print Controller, Stapler, Power Supply, Fuser Repair Catalog
G0-00732000
=^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
You need to use Toshiba drives with wipe technology. They are expensive and fail daily. Also before you update firmware on the newer machines you should check 05-9065, if the value of c5 is 1 or more you will need to replace the hard drive before updating the firmware. If you don't it might work for awhile but it will error out f101 within a day or 2.Comment
