Scanning locked out
  • JVC
    • Jun 2011
    • 151
    Scanning locked out
    Hello
    I have an Toshiba es4540c that I think was previously in a bank. Scanning was locked out in the admin mode of top access which I have turned to enable. Now I am not able to scan to the local hdd. When the customer presses scan he can press local mfp but the ok is locked out. On another note I have not been able to turn on the department codes for the machine and when I tried to do a factory reset in the admin mode it failed. I am digging through the service manual and not finding the answer. Does anyone know what I can do?
    Thank you in advance
    • 23009
    Re: Scanning locked out
    I've done this exact thing for PaperCut installed machine that have come back from lease. Do a 3C-3 HDD re-format, then proceed as if it were a new HDD. Guaranteed you'll be back to the factory settings. =^..^=
