Inactivity local mfp in scan 5540
  • ARMAN.MZ
    • Sep 2016
    • 100
    hello again
    in scan 5540 local mfp is Inactivity
    how to enable is?
    Telegram ID : @armanmahzun
    • 23007
    Re: Inactivity local mfp in scan 5540
    Can you re-phrase? I understand that you cannot scan. What type of scanning? SMB, FTP, Email, TWAIN, to the MFPs HDD? =^..^=
    • ARMAN.MZ
      • Sep 2016
      • 100
      see this
      Watch Free HD porn videos on the most popular porn tube in the world. Find hardcore porn of pornstars and milfs online. Stream porn your desktop or mobile.
      i another device this option is disable
      i want to enable it
        • 23007
        So you want to scan to the MFP's HDD. Have you checked the FILE_SHARE folder from a PC to see if your documents are going into the folder? Just note the destination in the scan screen, i.e.: //mfphostname/file_share
        Type it into the RUN:< screen of a PC on the network then OK. =^..^=
        • ARMAN.MZ
          • Sep 2016
          • 100
          i check it
          there is no FILE_SHARE folder
            • 23007
            Where are you looking? What destination? =^..^=
            • ARMAN.MZ
              • Sep 2016
              • 100
              with ip address in pc
              there is 2 folder print ps3 and pcl6
              There are three folders on other devices 1- folder-share 2-print ps3 3- print pcl6
              But in this device there are only two folders 1 ps3 2 pcl6
              folder share is gone
              • toshibaestudio
                • Jun 2016
                • 116
                DId u login TopAccess and check whether file share is disable???
                Save as local HDD = Enable
                SMB Restriction
                File Share โ€” Select this to enable SMB printing, but disable the file sharing service using SMB
