e studio 4555c error f101 sub code 1
  • Riviera
    • Sep 2016
    • 66
    [Error Code] e studio 4555c error f101 sub code 1
    I think the customer unplugged machine while in it was firing up. Now getting error F101 -1. Looks like hard drive but most likely it just needs to be reformatted
    Has anyone run into this before? Any info would be greatly appreciated.
    • 23010
    Re: e studio 4555c error f101 sub code 1
    Re-formatting the drive is a short term solution at best. Unless you're bored during the holidays, and need something to do ... then do again.
    • Riviera
      • Sep 2016
      • 66
      Holidays were pretty boring. lol But reformatting hard drives wasn't on my wish list.
      I haven't done anything to machine yet. I'm not real familiar with Toshibas, and I was just wondering if Reformatting would be the way to go. More like I was hoping it was. But I should know better. Anyway, I'm going to order a new hard drive from Hytec , but I have no access to OSS. If anyone can help me out with the software it would be greatly appreciated.
      • MUMMIM
        • Jan 2008
        • 125
        do you try to update firmware? i think you must try to update fist if it can't boot so you need order a new hdd
        • toshibaestudio
          • Jun 2016
          • 116
          F101_1 is ADI HDD error...
          Anyhow, u can try following before replacing new ADI.
          1. Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
          If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa)
          2. Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
          IF problem come back shortly, u need to replace new HDD & update latest firmwares.
          *Do ask your customers whether they shutdown the machine properly
          - If not, recover the key (copy "SRAM Key Status" to
          "FROM Key Status" or vice versa).
          • Riviera
            • Sep 2016
            • 66
            Thank you so much for all the info, and for taking time out of your day to help me out. I appreciate it very much.
            I followed all the steps and machine functioning again. My next issue is going to be getting customer set up for wireless printing again. That should be fun
            • vodo
              • Dec 2016
              • 36
              Replace your hard drive. Reformatted won't work. You will have error back.
