Toshiba 550 C46 code
  • tipsanders
    Need help with C46 code. Replaced fuser unit, thermistors, fuser control board, logic board, wiring harness (rear connector) etc. Any suggestions?
  • Baphomet
    Copier Technician
    • Aug 2008
    • 293
    I'm battling the same issue right now. In my case I have traced the harnesses and wires all the way back to J334 on the LGC board. Each time I clear 400 (which always has an 8 in it), as soon as the machine heats up ... pow ... C46. (Pow is my imaginary sound effects, it doesn't actually make a noise). I replaced the lower thermistor yesterday and got the machine going, then today same thing C46. I am going back tomorrow with a logic board ... but I would appreciate some help with this thread as well. I hope you don't mind me hitch-hiking on your thread tipsanders.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      power supply or line filter.
      Wall power?
      • Sbarro
        • 176
        Power supply for sure
        "A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it"
        What do you despise? By this you are truly known"
        Guess who
        • Baphomet
          Copier Technician
          • Aug 2008
          • 293
          Got this rascal fixed. There was a break in a wire in the wire harness which goes from the main connector on the fuser to the lower pressure roller thermistor. It was testing good on my meter because when I'd take it off to place my leads the wire would touch; but when I'd connect it the wire would shift apart in the insulation and loose continuity. A new harness corrected the problem.
          • Paul 75
            • Oct 2008
            • 97
            I had this aswell, replaced the wiring loom that sits under fuser, also there is a mod kit that spaces the rear and drawer block connector blocks.
            Oh...... I can't copy at the moment then ? !!!!!!
