Estudio 755
  • junidexy
    • Sep 2013
    • 32
    Estudio 755
    Hi
    I am Toshiba used Machine Seller,
    I gave machine to my client, he run around 300000 copier in that machine,
    now he has light print copier issue, when I service the machine , after 50 copies fine, again light print problem
    Toner adding problem is their , I change toner adding sensor also,
    can anyone help me on this to solve, pls
    Regards
    Junidex
    • 23007
    Re: Estudio 755
    When you ask about a quality issue, it's generally helpful to attach an image sample. =^..^=
      • 8193
      Re: Estudio 755
      What is the current meter read on the copier? Has the Developer been changed?
      Can you print off the PM support list and post it?
      Press 9 + Start and power on. Enter 103 press start.
