Toshiba E4500C - Functional Error Code SC369
  • rbloom
    • Aug 2025
    [Dead] Toshiba E4500C - Functional Error Code SC369
    I've searched for this code and cannot seem to find exactly what is wrong. The one I found indicates it is the drum motor. Does anyone know this to be true and if yes, how do I get this replaced? If we order, can we replace ourselves or should I search for a Toshiba technician? Thanks in advance for any assistance!
    • 8229
    Re: Toshiba E4500C - Functional Error Code SC369
    This is a relabelled Ricoh 3260c discontinued in 2009. Consider the copier scrap and get a new copier from Toshiba. Nobody is going to want to service it and you are past the seven year requirement for Toshiba to keep parts in stock for a discontinued product.
    • rbloom
      That's what I was afraid would be the answer. I kept hitting a dead end.
      Thank you.
      • rbloom
        Re: Toshiba E4500C - Functional Error Code SC396
        So, I suppose I was dyslexic when I typed the error code.
        SC396 is the actual code...does that change diagnosis?
        Thank you!
        • dlfowlks
          SC396 D
          Drum motor error 1: K
          As stated earlier this machine is obsolete. It will be hard to find parts for it. Good luck.
          • rbloom
            Originally posted by dlfowlks
            SC396 D
            RATS...well, I guess it would make a great boat anchor then. Thanks All!!
            Have a blessed day!
