e3555c scanner problem
  • didi2005
    • May 2011
    • 401
    [Misc] e3555c scanner problem
    Print counter list ok, but copy via RADF or glass, black band appear...
    Exposure lamp working properly, notice that the big glass a bit tilt...Will it be cable problem?
  • clint@clintsimonsen.com
    • 125
    Re: e3555c scanner problem
    Check mirror position springs. Has the machine been moved recently?
    Sent from my Nexus 5 using Tapatalk
      • 23010
      You've got an optical focus issue. It could be the mirror leaf springs like clint suggests.
      Or you might have a scanner rail slider come loose or broken. A few drops of straight 30W oil will make the scanner move smoothly
      Or the CCD height could be out of adjustment. I've seen a few CCDs way out of adjustment. A simple way to experiment before changing painted height adjuster screws is to loosen the two unpainted screws at the front of the CCD then make a few ledger copies. Then snug the front screws and loosen the two rear unpainted screws then make a few ledger copies. Now you can see what affect you would get by changing those adjustments. Now that you know which way to move, snug up all the unpainted screws, and go ahead and twist those height adjuster screws, and continue using ledger sized scans as your test. The trail edge of ledger is the most difficult part of the image to focus. =^..^=
      • didi2005
        • May 2011
        • 401
        Original glass tilt one side
        Mirror leaf spring attached
        Exposure lamp one side not touching ground
        The frame seems totally bend...
          • 8257
          There was a problem with the metal or bracing on the e3555/ e5055c series copiers. They were vulnerable to the metal frame, especially around the scanner area, to becoming bent out of shape by even moderate force such as someone leaning on the corner of the RADF.
          There is no recourse to fixing this problem and your copier might be a write off.
          The latest e3505AC/ e5005AC is a better design and less vulnerable to the frame loosing shape.
            • 125
            Did someone stand on that. Good luck with getting that straight enough.
              • 23010
              One of our in-shop techs used to use a scissors type automotive jack, and a couple of chunks of wood to straighten out this sort of situation. (Remove the tabletop glass first) =^..^=
              • arnh79
                • 469
                Would be more exciting if you left the glass in!
                Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
                • didi2005
                  • May 2011
                  • 401
                  Able to get back clear output without shadow by using car jack & hammer...
                    • 23010
                    Congratulations on your success! It's kind-of fun to take the 3# sledge hammer to the scanner frame. =^..^=
                      • 125
                      Nice work
                        • 8257
                        I think the British would say. "jolly good show, old man!"
                        • didi2005
                          • May 2011
                          • 401
                          Multi functional printer....Tech also need to be multi functional...
                          Need to do steel work, next time need to ask boss for welding course...
