change logo
  • ARMAN.MZ
    • Sep 2016
    • 100
    [CQ] change logo
    Hi
    Any body know how to change advertisement logo in toshiba ?
    Telegram ID : @armanmahzun
  • gliderider
    • May 2015
    • 131
    Re: change logo
    You did not specify the model. On current models code 08(9327) "Setting of banner advertising display".
    Codes 08(9328) allows changing of banner 1 (27 characters max) 08(9329) allows changing of banner 2
    • ARMAN.MZ
      • Sep 2016
      • 100
      Re: change logo
      thanks
      which model's can be change ?
      can upload photo?
      to when mfp turn on we see photo
      • clint@clintsimonsen.com
        • 125
        Re: change logo
        The banner advertising is on the screen most of the time along the a top of the screen, it is 2 lines of text. That alternate
        There is no way to change the software boot up logo, unless you custom write the firmware.
        Sent from my Nexus 5 using Tapatalk
        • ARMAN.MZ
          • Sep 2016
          • 100
          Re: change logo
          yes i know
          but in 4508 you can insert your image to logo
          but i dont know how?
            • 8207
            Re: change logo
            On the current eBridge Next products like the e4508A, you first need to create a .png image file measuring exactly 480 pixels tall x 800 pixels wide and install the same on a USB drive.
            Insert the USB drive into the copier and press the Gear icon located at the top of the LCD panel.
            Enter 123456 and scroll down to Edit back ground image. Upload your file into the copier and apply.
            As a value added service to your customer you can create a free png file from 301 Moved Permanently
            and follow the detailed instructions from this Youtube video.
