Toshiba 4520c Can't get scan to work error 2c69
  • jmart77
    • Mar 2006
    • 71
    [Error Code] Toshiba 4520c Can't get scan to work error 2c69
    The system is in a home office with a centurylink modem two computers and the copier. The printer works fine but I can't get the scan to work on this simple network.
  • guitar9199
    • Sep 2016
    • 1100
    Re: Toshiba 4520c Can't get scan to work error 2c69
    What error message are you getting?
      • 23009
      What kind of scanning are you trying to do? What credentials? =^..^=
      • Jasper Bürotechnik
        • Sep 2017
        • 26
        Hello, if the firmware is too old, then it does not go!
        Greeting Friedel
          • 8228
          At the Search Bar, type //IP address of the copier.
          When you see FileShare, create a short cut on the desktop.
            • Sep 2017
            • 26
            Yes, of course. If not scanned on a share Folder on the PC. Does it work that way.
              • 23009
              Yes you can scan to SMB. =^..^=
