model 3555e studio ERROR CE40....
  • Jedi Ben
    Senior Engineer
    • 77
  • Hansen88
    • 1056
    Re: model 3555e studio ERROR CE40....
    In my experience on the toshiba color machines that code is for developer units being low on mix. I know you redid the magenta but one of the others may be low too. Usually if you run a skyshot you will see the tiger stripes but sometimes they dont have to be that low to cause a problem. I have not worked on toshiba in a little while. Hope someone current will chime in.
      • 22999
      Hansen is correct. It's usually caused by depleted developer on one or more of the colors. It's handy if you can get a print, or even a good view of the latent patches on the belt, but if you can't just look at the developing cylinder. You'll see the diagonal voids on the mag roller when you rotate it.
      I understand that you had complications with broken stir augers and seized bushings (that's relatively normal). Once you get the developing unit repaired and vacuumed out, you'll pour in the new developer. Clear the developer counter in 6S-2 > Developer > Sub Counter > Magenta Developer > Clear > "Are You Sure?" > Yes. Remove the toner cartridge, then run the developer stir 05-2402 (wait until it's complete, then press OK). Re-install toner. Clean primary scorotrons and laser slit glasses via wands.
      Perform color calibration:
      05-2742
      05-4719
      05-4Fax, 05-7869
      05-70Fax, 05-8008
      05-230Fax, 05-8009
      It would be really good if you got a manual. =^..^=
