5540C
  • antone
    • Oct 2014
    • 344
    5540C
    Doc feeder...8 1/2 by 11 long edge when scanning...comes out like post card!Short edge comes out fine...Off the glass fine...only from doc feeder. Not sure what is causing this newbee...help
    Sent from my SM-N920V using Tapatalk
    • 23009
    Re: 5540C
    Are you saying that the image has not been properly rotated to suit the paper? =^..^=
    • antone
      • Oct 2014
      • 344
      Re: 5540C
      No when scanning on feeder...long edge...scans like post ...does not recognize the size
      • gliderider
        • May 2015
        • 131
        Re: 5540C
        If your originals are being sized incorrectly from the ADF I would check the proper operation of your size guides on the ADF. There are small copper fingers that come in contact with a circuit board and as the size guides are moved it tells the ADF what size original is loaded. Sometimes those fingers can break loose from their mount and cause the issue you might be having. You can check them in 03 mode. Power up in 03 press Start / make sure fax button is lit/ press 8. Then open your side guides all the way and slowly move them towards the center. C should be highlighted first, then as you move to the next size B then B+C then A+C.
