e Studio 306 White Void
  • copyguy69
    • Feb 2016
    • 94
    I have a white void that is produced by the developer unit. Swapped it out with another and problem is gone. The blade gap is correct and there is new developer in the unit. There is no void of developer on the mag roller and am wondering if there is something wrong inside with the mag roller itself. Anyone familiar with this issue? Any suggestions are welcome. Thanks in advance
    copyguy69
  • Vincent128
    • Sep 2015
    • 349
    Re: e Studio 306 White Void
    copyguy69
    Is the void lead to trail or op to non-op ?
      • 23008
      You may not notice a bare spot on the mag roller when it's sitting on the table, or when you rotate it by hand, but you can't agitate the developing unit at full speed. Most likely, there is a piece of fuzz or foam trapped behind the doctor blade. If you remove the blade assembly I think you'll find the obstruction. Be sure to properly adjust the doctor blade spacing when re-assembling. It's covered in the manual.
      • Vincent128
        • Sep 2015
        • 349
        I have found, rather than purchase those docblade cleaning mylars, that an inch or so piece of the banding used to hold together paper boxes works pretty good.
        you cut in a V notch..peel up end of V slightly...push in past V then pull back so the notches catch the back side of the blade...run it back and forth to cut off all the stuck toner and fuzz...push the mylar all the way in and retrieve it from the back side...dump/vac to your hearts content.
        • copyguy69
          • Feb 2016
          • 94
          Thanks for the replies. It was debris in the developer unit. Every time I rotated the roller is had no signs of anything bad but it was.
          copyguy69
            • 23008
            Congratulations on your success. =^..^=
