... and that's not all! When I tried to get into 9S the display came up blank. All the service modes and now the copy mode comes up blank screen. The interesting part is that the engine warms up and maintains temperature, and the hopper tops up the toner in the dev unit. So the engine is completely Ready ... but the UI has taken the day off. All the voltages are present at the power supply.
I've gathered a laser, PLG, SYS, and op panel for the followup call Has anybody seen this combination of symptoms?
I'm predicting that the SYS is the main cause, since both the op panel and PLG are routed through that board. It would sure help if I could use the machine diagnostics, but with the screen blank that seems unlikely. =^..^=
