Toshiba MJ1033 Paper exit issue
  • copyguy69
    • Feb 2016
    • 92
    The paper is feed out into the tray too far and then the staple misses a few pages. The paper does not jam it just seems to exit the finisher too far. Is there an adjustment for paper exit stop or a common issue with this finisher. Looked in the manual but did not see an adjustment for this. Thanks in advance
    copyguy69
    • 22929
    Re: Toshiba MJ1033 Paper exit issue
    There are a couple of flappers designed to pull the paper back into the stapler. Check to see that they are rotating, and actually pulling the paper back into the stapler. =^..^=
