Toshiba C6550 / duplex exit section questions
  • wild140
    • Feb 2017
    • 70
    I have one with 800+ K skewing pages as it exits the bridge unit and before the duplex section because there is a section between the two that has a set of rollers and the bottom rollers are obliterated by heat.
    I am having trouble identifying that section in the parts manual as well as finding in the SM how to remove that section or get to those rollers.
    I believe it is ADU-MID and the roller is #21 6LH8004000, 20181005_131647.jpgit is the roller under the gray roller pictured here.
    Can these be removed from the inside if I pull the duplex unit out ?
    Thank You in Advance for your assistance
  • clint@clintsimonsen.com
    • 120
    Re: Toshiba C6550 / duplex exit section questions
    If that is the unit I think it is take the fuser unit out, then the door switch cover at the front and then unplug the assembly,, then its just 2 screws and it slides out, I find it's some times easier to put it back in by removing the lower plastic cover above it. I keep a few if those black rollers in the car now as it's quite a common fault
    Sent from my F8331 using Tapatalk
    • wild140
      • Feb 2017
      • 70
      Thank You Clint , what you are describing sounds like the correct location. Do I have the correct part # ?
      • gliderider
        • May 2015
        • 131
        That part has been updated. The new part number is 6LH18004100 RLR-PINCH-14_NW. Those rollers are now white. Also you should take a good look at the guide the rollers mount to as it can warp from the heat also. I usually replace both. That part # is 6LJ07910000 Guide-exit-m.
        • wild140
          • Feb 2017
          • 70
          Thanks Again
