Toshiba ES8505A ADF Rabbit Ear
  • ameritech
    • 96
    Any one experience ADF rabbit earing on these models. I have two on the field with same issue. It's intermittant and cannot figure out. Thank you for the help.
    • 23010
    Re: Toshiba ES8505A ADF Rabbit Ear
    Are you sure that you got that model number correct? I don't think there is an 8505A. Maybe 4505AC? =^..^=
    • gliderider
      • May 2015
      • 131
      If your concern is with the DSDF then usually adjusting the DSDF height will resolve the intermittent dog ear problem. Your DSDF is most likely too low. Adjust the screw maybe one turn.
      • ameritech
        • 96
        Thank you. My apologize it's 6508a. I will check the height. Last time I actually lowered it. I will raise it this time. Thanks again.
