runnig time in warming up toshiba 455
  • ARMAN.MZ
    • Sep 2016
    • 100
    [CQ] runnig time in warming up toshiba 455
    hello my friends.
    i have a toshiba 455
    time to ready in toshiba 455 is 20-30 secound
    but in my device :
    when turn on device main motor run and (warming up) 30 second
    but a normal device is :
    when turn on main motor run (warming up) under 10 second and warming up next 20 secound
    That's what I've done
    i change hdd
    update
    reset 9090
    change 08-517
    change fuser roller
    change thermistor
    reset lgc boaard
    change lgc board
    but no change
    I'm grateful for your help in solving this problem
    Telegram ID : @armanmahzun
    • 23009
    Re: runnig time in warming up toshiba 455
    I've seen thermostats develop resistance at 180C, so the output from the lamps decrease. I've also seen lamps with hot and cold spots. So I think that I would change the lamps and thermostats. =^..^=
    • ARMAN.MZ
      • Sep 2016
      • 100
      ok your right
      but why main motor run 30 second
      if lamp or thermostats have problem must be error or need high time to warming up
      warming up time is ok
      my problem is main motor run 30 secound
      • rapidocument
        Multibrands Tech
        • Jul 2012
        • 381
        It might need a developer replacement,
        old developer=the machine runs longer to tone up at start and any other time during the day whenever
        the toner reference becomes low.
        Will also happen if you are using a cheap toner instead of OEM. (original).
        My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
        • riyadh hossainbd
          • Dec 2015
          • 239
          Originally posted by ARMAN.MZ
          ok your right
          Main motor running time depend on specific temperature
            hello my friends.
            but in my device :
            i change hdd
            update
            reset 9090
            change 08-517
            change fuser roller
            change thermistor
            reset lgc board
            change lgc board
            but no change
            wow.. did you THINK ( I know you didn't post ) life of ALL consumables? yes... an older dev unit/nonOEMtoner/Thermostats can all be a factor..
            BUT we really need to see: life on parts/fuser temp settings/error logs.. ya know VITAL INFORMATION. ( do you even have service manual? )
            why go shotgunning parts BEFORE you are absolutely SURE on the cause? Could you have been my GP when I was diagnosed with Diabetes?
            • ARMAN.MZ
              • Sep 2016
              • 100
              Thank you all fixed by 05-200
