MJ-1104 - Folding without stapling from PRINTING
  • pacman
    I can turn a screw...
    • 318
    Hey all, I have a question for you that's been wreaking havoc on me since forever. Does the MJ-1104 (specifically for 5540c/5560c/6570c) do booklet folding from the print driver WITHOUT saddle stitch stapling? I know you can COPY from the ADF and have it fold, but I can't ever seem to recall that being successful over multiple pages without getting an EAE0. We do know of the single page saddle stitch trick, but this is for multiple pages. So, 10 page Word document, 5 physical pages, can I just fold it?
    I assume workflow from the driver would be select paper size, bind on short edge and just checkmark the fold option. Is there a firmware upgrade that would allow me to do this? I just need to know if it's even possible with the MJ-1104.
    • 23009
    Re: MJ-1104 - Folding without stapling from PRINTING
    Not that I know of. =^..^=
      • 8213
      I believe from the print driver you can fold a single page without stapling.
        Technical data is subject to change without prior notice. All company and/or product names are trademarks and/or registered trademarks of their resp
        ective manufacturers in their markets and/or countries. All rights reserved. We are constantly making efforts to deliver the latest
        status of data to our partners. Specifications for some models may change in the time between the production and the release of this documentation. DS6
        530cGB0808
        OPTIONS
        2 trays, 3,250 sheet capacity
        50 sheet multi-position stapling
        A5R-A3, 64-105 gsm (staple mode)
        617 x 603 x 1,085 mm (W x D x H), ~ 40 kg
        Saddle-stitched booklets of up to 60 pages
        617 x 603 x 1,085 mm (W x D x H), ~ 70 kg
        • pacman
          • 318
          Thank you sir! That's what I was looking for.
          Almost tagged you with "Help me blackcat4866, you're my only hope!"
            • 23009
            Like you, I found a way to trick a bizhub 1052 with FS-532 and SD-510 into only folding a single page on multiple sets, but never could I get it to only fold multiple pages.
            Essentially you set it up to fold and staple, then insert only one original. It scans the original then tells you to load the rest of the originals. You leave the original tray empty and press Start again. And Voila! It prints and folds the job but does not staple a single page. I could not figure a way to get it to do multiples. I think it's little copier brain doesn't quite know how to deal with my illogical request.
            It would require special firmware I'd imagine. =^..^=
            • Ketchup
              • Jan 2019
              • 18
              This is correct, cannot do mutiples
              • Blizzoo
                • Aug 2013
                • 608
                Just thought about it and wanted to ask, wouldn't the staples play an important role for keeping multiple pages together for correct folding when the folding roller drags them? I mean to a set over 20-30 pages.
                • Ketchup
                  • Jan 2019
                  • 18
                  You can't do more than 15 anyway. I haven't been able to test this on a 1104 but we did on a 1112, and it will fold and not staple booklets per the tech on site.
