Toshiba 3540C Toners all say 100%
  • captain1976
    • Jul 2008
    • 79
    This thing will work without any toner cartridges and any cartridges put in all read 100%. Is there a 08 mode setting or something else to put it back to normal? I have about 5 machines sitting with the same thing. Thanks for any help
    • 23009
    Re: Toshiba 3540C Toners all say 100%
    If you tell the machine that you changed the cartridges, it will believe you and start again at 100%. Obviously it's going to run out of toner eventually. When the toner density starts dropping off it will ask for more, and go to 0%. =^..^=
    • captain1976
      • Jul 2008
      • 79
      The toner sensors are obviously shut off as they should not allow copies to be made without cartridges. Somewhere the must be a setting that will turn it on or disable them.
      Thanks for your reply though
        • 23009
        Take a look at pg 5-35 of the handbook. I suspect this was someones workaround for blowing toner cartridge EEPROMs (common on this series). Personally, if I figured out why it's doing that, I wouldn't change a thing since your machine is not blowing toner cartridge EEPROMs currently. =^..^=
