prevent ip conflict
  • daniel.eakins
    • Jan 2019
    • 10
    prevent ip conflict
    anyone know how to prevent device to reset ip when encounter ip conflict?
    device will set to 0.0.0.0, anyway to prevent that?
    Re: prevent ip conflict
    well some info on what TYPE of network....
    and maybe the MODEL of the unit?
    have you tried GOOD cables to/from copier?
    have you set it to pickup DHCP?
    are there lights on the NIC card?
    are you a tech?
    • daniel.eakins
      • Jan 2019
      • 10
      are you a tech?
      Hi Phil, thanks for your response.
      I'm newly touch in this field. previously in ATM field, just some basic in network skill.
      Its just that i see some device does not reset ip to 0.0.0.0, so just wonder is there a way to do it?
      at my customer place, the user set their own ip in their laptop. sometime the ip get conflict with device, then laptop get the ip and work alright. but device ip back to 0.0.0.0.
      Wonder any suggestion to prevent this?
        Yes... 1) their it dept can give you a list of captured ip's. 2) set copier to auto dhcp. 3) Capture that address and make it static (manual). I wouldn't do it to mobile devices unless approved by said it dept (I still wouldn't do it..liability for repair if it messes up). 4) imho if you go messing with PCs more than to load drivers or scan feat.. (new install) they should pay "by the hour" as long as you KNOW you can complete the job.
          • 29864
          do an cmd than a ipconfig
          get the pc ipaddress and add 50
          set the copier to static ipaddress
          • Bix
            • Apr 2018
            • 1421
            Here's how you can prevent IP conflict:
            1. Using cmd you write "ping IP ADDRESS" and check if someone answers you.
            2. You ensure that all devices (computers, smartphones, other printers, etc.) are switched on at the time of this check.
            A company with a large network and an IT that does not know the assigned IP addresses, the company must change IT.
            3. In some cases, the used IPs remain in the router. You can take inspiration.
            • didi2005
              • May 2011
              • 401
              U can try disable IP Conflict Detect via TopAccess.
              • daniel.eakins
                • Jan 2019
                • 10
                disable ip conflict in TopAccess? Could you enlighten me?
                i quite new about toshiba device here.
                  • 22997
                  The short answer is the only thing for you to do is identify the dupe. Use a utility like SoftPerfect Network Scanner. Unplug the MFP. Scan the network for the specific IP. Note the Mac address of the offending device and the manufacturer, then present it to their IT. It's up to them to assign/re-assign IP addresses.
                  • toshibaestudio
                    • Jun 2016
                    • 116
                    What blackcat mentioned is the best practice...
                    When printer ip address is in static mode, the ip address must reserved for the printer, otherwise if 2 same ip address is used, u will have printing error even the printer side ip address do not reset to 0.0.0.0 ...
                    If u can't get help from the IT/network vendor, what u can do is set the printer ip address in dynamic mode, install printer driver using MFP hostname instead of ip address.
                    • NeoMatrix
                      Senior Tech.
                      • 3514
                      daniel.eakins
                      When clicking the user profile, the above user name comes up as "Invalid user Name" contact system administrator.
                        • 29864
                        If its an enterprise or if they have IT , have them do a reservation by Mac address for the copier
                          • 22997
                          daniel.eakins
                          I don't think the forum likes the period in the username. I suspect it may be treating it as a web link.
                          • daniel.eakins
                            • Jan 2019
                            • 10
                            i have notified admin, let see is there any advice from admin regarding the "invalid user name" issue.
                            thanks anyway.
                            • NeoMatrix
                              Senior Tech.
                              • 3514
                              A simple multiple ping batch file to test for conflicting or unauthorized IP addresses on any network.....
                              hhttp://www.copytechnet.com/forums/connectivity/97276-all-one-i-t-tech-software.html#post730769
                              http://www.copytechnet.com/forums/co...tml#post730769
