E Studio 355 Toner fusing
  • yormets
    • May 2009
    • 336
    My E Studio 355 has a problem fusing toner to the paper. I replaced the fuser rollers and put the tension springs in the most tension slot. I do not have a service manual. What 08 Code sets the fuser temp? Is is the same code as some of the older models? Like the 350/450 series? Any help would be appreciated.
    • 23006
    Re: E Studio 355 Toner fusing
    What media gsm are you using?
    What media type is selected for the affected trays?
    Don't you think that this is pertinent? =^..^=
    • tsbservice
      Field tech
      • 8006
      Original toner?
      • yormets
        • May 2009
        • 336
        OEM Toner. It is thick paper being run through the bypass properly set up as to what media is on the bypass tray. The media is acceptable according to specs. The machine has 270K and I have no idea if the fuser has ever been paid attention too. So I replaced the rollers, increased the spring tension and wanted to boost the temp as a final task.
          • 8185
          Does the toner properly attach to 20 lb bond paper? Is the thick paper textured as in not perfectly smooth?
          This is an old copier, long discontinued. Toshiba will discontinue all support on 03/2020, one year from now.
            • 23006
            So what gsm, with what media type? =^..^=
            • davod.mardani
              • Feb 2015
              • 32
              In Setting Mode (08)
              407, 410, 411 , 450
              Default value is "8"
              Each unit equal 5 degree
              Sent from my Mi A1 using Tapatalk
              • yormets
                • May 2009
                • 336
                407, 410, 411 , 450
                Thank you very much.
