In E-Studio 350 i am facing RADF jam always. E721 Error code on display. If we put A4R or A3 there is no issues. its working fine. This error happens only in A4.
First clean read sensor it can be dirty, second replace read roller, this is a big roller which moves paper it will solve your E721 jams.
I am having the exact same issue. Can you confirm if the change of Read Roller fixed your issue please?
I have cleaned and tested read sensor and it is fine, but the paper (if A4 orientation) just seems to stop before it hits it. This does not occur with A4-R, which scans perfectly fine. The pickup and separation rollers are also brand new.
I know this is an oldie, but it's a truly odd situation.
This is what I found:
These "T" shaped mylar guides just past the white plate were all worn completely through to the adhesive, leaving jagged edges to snag and exposed adhesive.
Naturally I didn't have replacement mylars, but I cut new ones from what I had in stock. They work quite nicely. =^..^=
