E350 RADF Jam
  • vasan_rsri
    • May 2025
    E350 RADF Jam
    In E-Studio 350 i am facing RADF jam always. E721 Error code on display. If we put A4R or A3 there is no issues. its working fine. This error happens only in A4.
    Kindly suggest any solution.
  • aalex_bom
    • Jan 2008
    • 214
    change PAPER size in tray
    ""This error happens only in A4. """
    are you sure bypass ? if not you try on change paper size in tray.
    08-225 select A4
    08-226 select A3.
    and check.
    good luck
    • vasan_rsri
      E350 RADF Jam
      Alex Thanks for u reply.
      I am taking about the original size. Not the copy paper size. This Jam happening even while scanning also.
      Thanks in advance
      • atudorica
        • Oct 2007
        • 79
        try to initiate df:
        05-356
        the do:
        05-367,368
        • vasan_rsri
          Even the 08-356 didn't help. Still the same.
          • tsbservice
            Field tech
            • 7911
            First clean read sensor it can be dirty, second replace read roller, this is a big roller which moves paper it will solve your E721 jams.
            • sambo
              • May 2011
              • 60
              Re: E350 RADF Jam
              I am having the exact same issue. Can you confirm if the change of Read Roller fixed your issue please?
              I have cleaned and tested read sensor and it is fine, but the paper (if A4 orientation) just seems to stop before it hits it. This does not occur with A4-R, which scans perfectly fine. The pickup and separation rollers are also brand new.
                • 22930
                Re: E350 RADF Jam
                I know this is an oldie, but it's a truly odd situation.
                This is what I found:
                These "T" shaped mylar guides just past the white plate were all worn completely through to the adhesive, leaving jagged edges to snag and exposed adhesive.
                Naturally I didn't have replacement mylars, but I cut new ones from what I had in stock. They work quite nicely. =^..^=
                • toshibaestudio
                  • Jun 2016
                  • 116
                  Re: E350 RADF Jam
                  What i use to do...
