Toshiba Estudio 757
  • kshar
    • Apr 2019
    • 3
    [CQ] Toshiba Estudio 757
    My customer has a Toshiba Estudio 757 that has dark background. Changed developer unit with developer. Set developer and same problem. Any help would be appreciated.
    • 22699
    Re: Toshiba Estudio 757
    May we see an image quality sample? Did you run 05-2000?
    • kshar
      • Apr 2019
      • 3
      Yes. Ran 05-2000. All gray background but can see image.
      toshiba 757.pdf
        • 22699
        Did the developer balance between 234 and 246? =^..^=
        • kshar
          • Apr 2019
          • 3
          Yes it did
            • 22699
            I had a 557 recently that turned out to be wrong toner. It was a Toshiba tube, but I suspect the customer spoon fed it something else.
            Like most wrong toner situations, the only place the toner doesn't want to be is in the toner hopper or developing unit. The machine was a toner explosion. When I dumped the developer there were two distinct components that would not mix, the toner and developer. =^..^=
            • kashif
              • Apr 2013
              • 45
              plz decrease value of developer bias, look like biasing problem
                • 22808
                The OP just SAID the dev bias was WHERE IT IS SUPPOSED TO BE!
                BC asked "Did the developer balance between 234 and 246? =^..^="
                kshar replied " Yes it did"
                Please read ALL comments B4 responding!
                • toshibaestudio
                  • Jun 2016
                  • 116
                  This problem happen since e600 series...Check & service toner drive...And drum unit as well especially main charger...
                  • Luther
                    • May 2006
                    • 682
                    clean the ground contacts in the drum and the drum shaft
                    • Ketchup
                      • Jan 2019
                      • 18
                      You wasted your time of Dev unit, just fyi. They might lock up on you, but its never the dev units fault on this.
                      Are the erase leds working? Whats the PM values at?
                      • lazymangr
                        • Feb 2017
                        • 115
                        looks like erase led not conected. but check also the mylars on both ends of developer if its torn or has a small hole and/or doctor blade if its in spec space
                        • JoeK
                          • May 2017
                          • 21
                          I think you may be on to something, though thats nothing new. I worked on Sharps for 2 years but new company is Toshiba. How the page has a grey background on sharps would have almost garunteed a developer problem. Atleast personally I have never scene it where replacing the developer didn't solve this. Which of course bad toner could make it look like the developer is bad.
