Toshiba 456
  • kashif
    • Apr 2013
    • 45
    Toshiba 456
    i have toshiba 456, my copier is giving initial print but when i am trying to make copy, paper stuck in registration, i changed board but same issue, someone can help?
    • 23007
    Re: Toshiba 456
    A jam code might be good to know. =^..^=
    • kashif
      • Apr 2013
      • 45
      Re: Toshiba 456
      No boss there is no any jam code, just machine is giving paper jam.
        • 23007
        Re: Toshiba 456
        You're going to have to figure out how to get the jam code, if you really want help. =^..^=
        • toshibaestudio
          • Jun 2016
          • 116
          Re: Toshiba 456
          The paper jam/stop at drum unit cannot go up? Probably the main drive drum shaft pin broken...
          • davod.mardani
            • Feb 2015
            • 32
            Re: Toshiba 456
            Hi
            When the jam paper , the key C and 8 are displayed at the same time as the jam paper error code is displayed.
            Sent from my Mi A1 using Tapatalk
              Re: Toshiba 456
              throwing the BULLSHIT flag...
              in 31yrs I have NEVER know ANY brand NOT to give a jam code.....
              • davod.mardani
                • Feb 2015
                • 32
                Re: Toshiba 456
                Wow!
                I do not repair without jam paper code.
                • lazymangr
                  • Feb 2017
                  • 115
                  Re: Toshiba 456
                  the thing that people change mfb boards like shirts its above me. paper jam? change board. lines on copy? change board.
                    Re: Toshiba 456
                    hmmmm could it be those folks don't have a friggin' CLUE?
                    you can't fix ANYTHING ( printer - car - lawnmower - boat )
                    by just throwing parts at it.. (unless you're Bill Gates)
                    you must be in the BALLPARK in the diags
                    therefore knowing the BASICS of operation of the thing you are working on.
