Toshiba Studio 452 hang up
  • gregoriojc
    • Aug 2008
    • 56
    Hello guys Im facing a problem on toshiba sudio 452
    hang up, when i put on the machine the lcd displays shows and theres no any btton or light indicators are on, heres the snap shop of the lcd panel ..
    at the attachment pls. help
    joseph
  • tsbservice
    Field tech
    • 7974
    Try 08/690 press 2 then set. Next thing is new HDD and new firmware.
    • gregoriojc
      • Aug 2008
      • 56
      Can not enter to program mode, i have the hdd but i dont have firmware,
      pls could you help me to get firmware for this machine and the procedure to download the firmware.
      thanks
      joseph
      • aalex_bom
        • Jan 2008
        • 214
        firmware update
        i have e350 and problem same.
        can you send for me??
        my e mail ": nhatthuc0000@gmail.com
        i posted SH 350 - mode 08
        thanks
        • gregoriojc
          • Aug 2008
          • 56
          thanks a lot
          i will try these procedures and about the firmware still not get.
          when i have ill share it to you.
          gregoriojc
          • jawir
            • Aug 2007
            • 107
            I have similiar case like this before and after I change with new NVRAM it work fine. I did not try update the firmware.
            regards
            • Naveed Shahid
              • May 2008
              • 162
              Dear brother i am also faced problem same like ur i upgrade firm ware version and solve the problem
              joseph
              • aalex_bom
                • Jan 2008
                • 214
                if HDD gone down, you must attach new HDD and load FW
                • gregoriojc
                  • Aug 2008
                  • 56
                  I got new hdd but no fw loaded, I took another machine hdd and clone it using norton ghost, it works well
                  thaks guys
                  • crazy
                    • May 2011
                    • 15
                    if it isn t hdd problem look at ram on sys board or change sys board
                    • michaelc
                      Field Tech
                      • Mar 2011
                      • 590
                      It could need a HD format, and firmware.
                      It didn't say that I couldn't do it in the manual.
