e-studio 255 256 and the like registration problem
  • bruce 49dcs
    • Jan 2017
    • 140
    anyone come across bad registration( leading edge entering to soon causing the image to shift to the rear but not enough to jam) caused by something other than the clutch
    first prob bad feed on adf then i put a good adf and did ufr and pics then reg prob showed up so i tried another adf same prob put in a used clutch from a working machine same prob
    Its been the clutch in the past but it was fine before i worked on it now im in trouble HELP PLEASE
  • gliderider
    • May 2015
    • 131
    Re: e-studio 255 256 and the like registration problem
    Do not use the adf to confirm registration problems. Keep it simple. Put a test chart on the glass and run off 30 or 40 copies and check if the registration is changes. If so, I would go back at the reg clutch. You didn't say if you were experiencing any jamming either. You may have introduced other issues if you started changing adf's or settings. Also I would not be using a used reg clutch to troubleshoot!
    • toshibaestudio
      • Jun 2016
      • 116
      Registration clutch is one of the common problem on this series, when print many pages, the images will shift resulting jam.
        • 23006
        Another common cause of varying registration is a broken front door strap, or maybe an incorrectly assembled transfer roller assembly.
        • BTech21
          • Jun 2019
          • 12
          Check the registration and 1st transport sensor flags. The original shinny plastic actuators would wear quickly.
