3508 Toshiba
  • antone
    • Oct 2014
    • 344
    [CQ] 3508 Toshiba
    Errors E020 ...paper gets half way in to fuser jams ! Replaced exit sensor same jam ! Any hints!!
    Sent from my SM-N950U using Tapatalk
  • davod.mardani
    • Feb 2015
    • 32
    Re: 3508 Toshiba
    Hi
    Always when E020 Occurred that's mean EXIT sensor is OK!!!
    Check Fuser Gear drive, check exit roller mechanism.
    Sent from my Mi A1 using Tapatalk
      • 23007
      Re: 3508 Toshiba
      Do you have adequate image voids, especially on heavy fill images? =^..^=
      • Vincent128
        • Sep 2015
        • 349
        Re: 3508 Toshiba
        is that the model that has the adu divert gate there that if the customer broke in half then made disappear; you don't realize there is a part missing ?
        also I have had some machine jam seeming for no reason there, a few bulletins about it - exit divert gate modification, fuser top cover mod.
        check the positioning of the exit divert gate solenoid, we had to add a wrap to the fuser exit spring on one.
