Toshiba estudio 3508a error f101-1
  • etsmultan
    • Apr 2007
    • 131
    [Error Code] Toshiba estudio 3508a error f101-1
    Can any body help me to resolve F101-1 in Toshiba e studio 3508a.If some one has firmware pls send me..mmazhar.javed@gmail.com
  • antone
    • Oct 2014
    • 344
    Re: Toshiba estudio 3508a error f101-1
    replace HDD
    Sent from my SM-N950U using Tapatalk
    • Copier & printer
      • Sep 2019
      • 4
      Toshiba 3508A If some one has firmware pls send me.. umar.farooq1301@gmail.com
        • 8081
        HDD, SYS board, Setting 1. Turn the power of the equipment OFF and check the
        connection of the HDD.
        - Connector and harness check
        - Check if the connector pins of the HDD are bent.
        - Check if HDD for other equipment is not installed.
        - Check if SRAM for other equipment is not installed.
        2. If the error still occurs after step 1, perform the following.
        - Perform HS-73 Firmware Assist mode -> Key
        Backup/Restore and check that each Key Status is
        "OK".
        - If not, recover the key (press [Key] and select the
        menu, and then press [Execute]).
        3. If the error still persists after step 2, perform the
        following.
        - Perform HS-73 Firmware Assist mode -> Format
        HDD, and then install "System software" (HS-49
        Firmware Update mode -> SYSTEM SOFTWARE
        (HD Data)).
        Notes:
        The following items will be deleted by HS-73
        Firmware Assist mode -> Format HDD.
        If F101_1 occurs with secure HDD or the error
        persists after performing step 3, perform step 3 after
        performing HS-74 HDD Assist mode -> Revert
        Factory Initial Status HDD.
        4. If the error persists even after step 3, replace the HDD.
        5. If the error persists even after step 4, replace the HDD
        harness.
        • Copier & printer
          • Sep 2019
          • 4
          I try this not work f101 still
            • 22927
            Specifically, what did you do? =^..^=
            • samarik
              • Mar 2021
              • 6
              "OK".
              following.
              (HD Data)).
              Notes:
              harness.
              I have this Error F 101 will Do the steps and reply hope this will work for me reply need some time for assembling.
              • samarik
                • Mar 2021
                • 6
                Hey... its working 100 % thank you so much all steps has been followed completed in step 3
