we have just unboxed an 3015 and removed all packing parts etc and on power up it errors c262 at the end of loading I have disconnected the DF and re seated the ccd cable on ccd and the main board to no avail has anyone had this problem or is it most likely the ccd thanks for any input
e3015ac with error C262
Re: e3015ac with error C262
Is the scanner still locked? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
g โ imgbb.com
gg โ imgbb.comComment
Congratulations on your success! =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
