e3015ac with error C262
  • slot
    • 341
    we have just unboxed an 3015 and removed all packing parts etc and on power up it errors c262 at the end of loading I have disconnected the DF and re seated the ccd cable on ccd and the main board to no avail has anyone had this problem or is it most likely the ccd thanks for any input
    • 22985
    Re: e3015ac with error C262
    Is the scanner still locked? =^..^=
    • abc mfp
      • Aug 2019
      • 12
      Make sure to remove the 2 screws that locked the scanner carriage...
      • slot
        • 341
        thanks guys they were all removed when the df was fitted its being sent back to toshiba
        • Toshiba-Claudio
          • Dec 2019
          • 8
          I solved this problem this morning, I replaced the scanner
          g — imgbb.com
          gg — imgbb.com
            • 22985
            Congratulations on your success! =^..^=
