toshiba 166
  • ARMAN.MZ
    • Sep 2016
    • 100
    [CQ] toshiba 166
    toshiba 166
    print have no problem.
    but copy : is many line in center of paper (top photo)
    i replace flat
    CIS
    the problem still there (down photo)
    i want test main bord
    i have a toshiba 163 main bord
    and install in toshiba 166 get error :C26
    Telegram ID : @armanmahzun
    • 8177
    Re: toshiba 166
    That copier was discontinued so long ago that Toshiba Tec does not provide the service manuals anymore.
      • 23003
      Re: toshiba 166
      Are all the optics clean? Is the white plate clean and white? There must be some sort of calibration for the CIS... ?
      • Blizzoo
        • Aug 2013
        • 608
        Re: toshiba 166
        eStudio 163/203 CIS Unit PN - 6LE64010000 SNSR-CISM-280 have a different part number/name description than eStudio 166/206 6LH25860000 ASY-CIS-284 so it won't work, different machine series
        Main Board e166 PN - 6LH28100000 not the same as Main Board e163 PN-6LE63158000 = they don't match
        C26: Peak detection error
        Does the exposure lamp light? (Perform the output check in the test mode: 04-267)
        YES �� Replace the CIS unit.
        NO
        1) Check if the connector of the CIS unit are disconnected.
        2) Check the MAIN board if the connector (CN6) is disconnected and the harness is short
        circuited or open circuited.
        3) Check if the conductor pattern on the MAIN board is short circuited or open circuited.
        4) Replace the MAIN board.
        5) Replace the CIS unit.
        You need a e166/203 CIS UNIT to test or e166 Main Board only in your faulty e166.
        Check what Blackcat said about the white reference plate under scanner glass, must be clean.
        • tsbservice
          Field tech
          • 8002
          Re: toshiba 166
          NO
          Totally agree, although my glorious days with Toshiba are gone. Still worth it to check and clean optics and especially white plate reference strip BC mentioned in case of C26 error.
            Re: toshiba 166
            wish the OP would respond to some of these questions.
            WHY did he start replacing PARTS before thoroughly cleaning EVERYTHING?
            are the copies of printed paper? ( defect on org .. not noticed but when copied defect more prevalent)
            my bet is not properly cleaned optics.
            were these NEW/known good parts?
            • sakisvas
              • Nov 2016
              • 33
              Re: toshiba 166
              Originally posted by ARMAN.MZ
              [ATTACH=CONFIG]44518[/ATTACH]
              toshiba 166
              i replace flat
              CIS
              [ATTACH=CONFIG]44519[/ATTACH]
              Dear friend,
              you have problem in main ..
              i have many machines with these problem (Contracts with Banks) .. some capactior failed..
