Toshiba 5055C Hard Disk
  • badrobot
    • May 2020
    • 22
    So I re-imaged the hard disk on the copier a couple days ago and it failed again. Leading me to believe I have a bad disk, does anyone know if you can use any hard disk for replacement as long as it is the same size? Or does Cylinder, heads and sectors matter? Also do you need to format the disk to a specific format prior to installing or will the copier format option work regardless of that aspect?
    Any help would be appreciated.
    • 23007
    Re: Toshiba 5055C Hard Disk
    NO. It must be a Wipe Drive. You may not substitute. =^..^=
    • badrobot
      • May 2020
      • 22
      Not really sure what you mean by a wipe drive, unless you are referring to the concept of wiping a drive but even then you would still need the specific format. Can you elaborate more?
        • 8195
        You must install a Toshiba original Secure Encrypted HDD aka SED-HDD. No other form of off the shelf HDD will work.
        Wipe Drive means that if the original SED-HDD is removed from the Toshiba copier and any other device attempts to read the data, the SED-HDD will automatically remove the encryption key from that SED-HDD effectively wiping all data on the SED-HDD and rendering it permanently non functional.
        • badrobot
          • May 2020
          • 22
          Thanks for the more in-depth explanation. It Helps!
