Toshiba 3005AC Rainbow running Lengthwise on certain halftones
  • buzz
    • Aug 2013
    • 288
    I seen a previous post a few months back, but was for a different model. Sorry if its redundant.
    Here's the samples. Its not super obvious, but it is recognizable with it in hand.
    The rainbows are subtle. It shows up on these prints with a light tan halftone graphic.
    I have CMY drums and rebuild kits with grids on order.
    Would this be the step in the right direction? Any feedback would be great.
    What counters and calibrations do I perform after rebuilding these?
    Thanks so much!
    • 23010
    Re: Toshiba 3005AC Rainbow running Lengthwise on certain halftones
    PM interval for the 3005AC is 180K black, 90K color. (3) color rebuild includes (3) drums and EPU-KIT-FC505CLR.
    You'll need to do the (3) color developer stir, and color calibration. Before you start, I'd suggest printing off the FS-30-103 PM list.
    Excuse me please if I won't read you the manual. You seem perfectly able to read the procedure to stir the developer and do a color calibration for yourself. And when you figure it out for yourself you'll get that good feeling of figuring it out for yourself.
    If you'd like a more detailed analysis print these pages, then show them to us:
    • Vincent128
      • Sep 2015
      • 350
      Oooo...this is a new version of your file me thinks. *yoinks*
        • 23010
        I did a revision about a year ago. If you're looking for a specific paper size just say so.
        • tomasreabe
          • Oct 2024
          • 4
          Hello, I think I have a similar problem but it appears to be on all colors not just a single one.
          Wondering if this is a transfer belt issue or where I should start looking.
          Estudio 3505AC
          • Rusty.Harris
            • Jan 2021
            • 639
            Estudio 3505AC
            Measure the distance between the start of the first blank area, to the end of the blank area to give you the diameter of the blank area. That will help track down what could be causing the issue as it is a repeating problem.
            • tomasreabe
              • Oct 2024
              • 4
              Printing an 11x 17 it repeated every 3-3/4" so that would be a 1.2" roller or so.
                • 23010
                There are three choices for that (94 to 96mm):
                Fuser film (usually reprints image elements down the page)
                Drum
                Facing roller (Poor ground connection to the facing roller in the transfer belt unit)
                I'm leaning towards the facing roller ground contact. =^..^=
                • tomasreabe
                  • Oct 2024
                  • 4
                  Drum
                  Is there a specific maximum reisistance I should be looking for?
                  I did see resistance going up to 1M ohm so I know that is not good.
                    • 23010
                    um ... yeah, 1MΩ is bad. The correct resistance between the roller and the contact vary at ≤0.10Ω. Keep in mind that's rolling resistance. When it's not rolling, the resistance will increase significantly.
                    • tomasreabe
                      • Oct 2024
                      • 4
                      So I did replace the transfer belt assembly, I could not finde where to order the bearings that were causing the high resistance.
                      The new assembly has a resistance around 4-6 ohms, so much better and the image is much improved.
                      does anyone know where to get just the bearigns from as I did find a few rollers that do have similar bearings that the ohms resistance is realy high. 250K to 500K
                      Thanks for all the help
                        • 23010
                        There is a wire leaf spring that makes physical contact between the facing roller and the electrical contact. It's easy to displace this leaf spring when disassembling.
                        • Munter
                          Member
                          • Jul 2011
                          • 25
                          I'm not familiar with this term. When you say "facing roller" am I correct in assuming you are talking about the roller inside the Tx belt that the secondary Tx roller indirectly presses against?
                          Also, could you provide that ANSI A file for A4 paper, please?
                            • 23010
                            Yes, that's correct.
                            Is this what you want? =^..^=
                            • Munter
                              Member
                              • Jul 2011
                              • 25
                              Awesome. Thank you very much. 😁
