toshiba estudio 452 paper size issue
  • alamin
    • 3
    [Misc] toshiba estudio 452 paper size issue
    I have an issue regarding paper size of toshiba e-studio 452. standard paper size of my copier is LT/LD, I want to change it to A4/A3 format. Can anyone please help me..?
    • 23003
    Re: toshiba estudio 452 paper size issue
    Look under System Menu > Drawer > then choose whatever USA or Metric size you like. Just keep in mind that if the actual paper size does not match what you programmed you'll get E061, E062 paper size mismatch jam codes. =^..^=
    • alamin
      • 3
      thanks for your reply sir. can you please tell me how can i change this menu paper size ? (see the image)
        • 23003
        That menu is for the bypass tray. Place paper in the bypass tray > that menu will pop up>
        > select the paper size that you desire.
        • Blizzoo
          • Aug 2013
          • 608
          On the Control Panel press the User Functions Button -> select User -> select Drawer -> Set desired Paper Size for each Drawer
          Hope this helps
          • aalex_bom
            • Jan 2008
            • 214
            08 + Power on > access 201 set 0 or 2
