toshiba estudio 452 paper size issue
  • aalex_bom
    replied
    Re: toshiba estudio 452 paper size issue
    08 + Power on > access 201 set 0 or 2
  • Blizzoo
    replied
    On the Control Panel press the User Functions Button -> select User -> select Drawer -> Set desired Paper Size for each Drawer
    Hope this helps
    replied
    That menu is for the bypass tray. Place paper in the bypass tray > that menu will pop up>
    > select the paper size that you desire.
  • alamin
    replied
    thanks for your reply sir. can you please tell me how can i change this menu paper size ? (see the image)
    replied
    Look under System Menu > Drawer > then choose whatever USA or Metric size you like. Just keep in mind that if the actual paper size does not match what you programmed you'll get E061, E062 paper size mismatch jam codes. =^..^=
  • alamin
    started a topic [Misc] toshiba estudio 452 paper size issue
    I have an issue regarding paper size of toshiba e-studio 452. standard paper size of my copier is LT/LD, I want to change it to A4/A3 format. Can anyone please help me..?
