Toshiba 2050c error
  • MacTavishLK
    • Nov 2020
    • 68
    Toshiba 2050c error
    Call for service C3A0. How to reset this error code? Please help me immediately.
    • 8239
      • 23009
      Re: Toshiba 2050c error
      On a machine of this age the magenta developer may be depleted or the developer bearings may be leaking ... probably both.
      Reset? You can just forget that. =^..^=
      • Rusty.Harris
        • Jan 2021
        • 635
        Yuck...on a 2050, you'd be better off upgrading to a new one. That Machine
        came out around 2012. It isn't on the obsolete list, but probably will show up
        on the list November 2021, which means it will be DOA March of 2022.
        The developer unit is probably shot. Those things will leak past the v-ring
        seals, chew up the bearings and deplete the developer.
        • copierlady
          • 338
          I actually had a machine throw this code after I had cleaned it, and it was just out of M toner. Don't know why it didn't just tell me it was out of toner. Just an FYI for you guys. Had me doing way to much work trying to figure it out!
            • 23009
            Another thing to watch for, especially on the eS2505 series, is the lower developer duct filling with developer, immersing the toner sensor in developer. If that duct isn't emptied and cleaned when the unit is tipped (like during a developer change), the new developer will not read correctly.
            The good news is that it's recoverable. Cover the upper openings and invert the full developing unit. The lower duct can then be removed. Remove the toner sensor and tap the teaspoon of developer out of the toner sensor housing. Re-install toner sensor, and vacuum out the duct. Re-install the lower duct, and re-run the developer stir.
            After the second time, I now clean that lower duct on all eS2505 series machines if I handle the developing unit.
            @MacTavish: What did you find? =^..^=
