MJ-1112 ribbon cable
  • tnrtt
    • 156
    Been through the parts manual four times and can't find the ribbon cable that connects the SDL and main PCB's. If someone could give me the page and item number, I'd appreciate it.
    • 23010
    Re: MJ-1112 ribbon cable
    How about this?: 6LK58211000
    Literally the last item in the catalog.
    • tnrtt
      • 156
      [ATTACH=CONFIG]47843[/ATTACH]
      Thanks a lot blackcat. Where did you get that image? My parts manual is from FYI, looks nothing like that.
        • 23010
        That's RIBON. It's a Toshiba proprietary application that organizes you parts manuals into a single application. =^..^=
        • tnrtt
          • 156
          Thanks. I'll check it out. Looking at it right now on FYI. Still don't understand why I couldn't find it in the tech to go parts manual
          • tnrtt
            • 156
            Not to beat a dead horse BC, but I plugged the number in my search on my manual. It appears you have to buy the plate it's glued on. Luckily Toshiba has one in stock. Just one.
              • 23010
              Yes, I saw that. If it was HP you'd have to buy the whole finisher. =^..^=
