MJ-1112 CB95 code
  • tnrtt
    • 156
    MJ-1112 CB95 code
    Had a chewed up ribbon cable. Replaced it and got the code. Replaced stacker motor home position sensor. Stacker motor drives past home position. I'm not getting 5 volts cn8 pin 5. I think it's the saddle control PCB. My boss wanted me to post this for other possible causes.
  • Rusty.Harris
    • Jan 2021
    • 634
    Re: MJ-1112 CB95 code
    Probably not the same, but if you get a bunch of EF-14's, it will trigger the CB95. I had this happen a few years back on a
    similar finisher. Remove the lower front cover that covers the saddle unit. Ensure the rod for the folder and everything has
    not popped out of its position. Loose screw...
