5055C Call for Service C970
  • badrobot
    • May 2020
    • 22
  • Rusty.Harris
    • Jan 2021
    • 620
    Re: 5055C Call for Service C970
    There was a bulletin about the charge corona causing the C970. The plastic around the front of the cover of the charge
    corona, would not allow the frame to make proper ground connection. They changed the plastic just a bit to fix the
    problem. In the field, when we didn't have the part, we just shaved off the excess area and it solved the problem.
    • mojorolla
      The Wolf
      • 2583
      I think he is referring to these:
      There is also a change in the ends, the originals were gray, the new style ones are black.
        • 22997
        Also common on these the Weisshorn High and Low, the seesaw (the plastic rocker that tensions both the needle electrode and grid) breaks, dropping the needle electrode onto the grid. I've replaced quite a number of these, and repaired almost as many.
        The C970 is not specific to a color, so any of the four primary charge units can cause this, and it can be very intermittent. Usually, I examine all four primary charge units from gross defects, like the broken seesaw or the needle electrode twisted 90 degrees down it's length (you'd think that would be pretty obvious, but I've found it a couple times). If you can catch it in the act, the affected color drum with be blanketed with toner:
        If there are no gross defects, I'll examine the test charts and focus on the color primary charge unit that is most poorly calibrated. It's you're best odds of getting the correct one. =^..^=
        • Rusty.Harris
          • Jan 2021
          • 620
          [QUOTE=blackcat4866;1681505]Also common on these the Weisshorn High and Low, the seesaw (the plastic rocker that tensions both the needle electrode and grid) breaks, dropping the needle electrode onto the grid. I've replaced quite a number of these, and repaired almost as many.
          I got so tired of replacing those, that I just gave up, drilled a tiny hole, and looped the spring through it instead of replacing them LOL.
            • 22997
            Like this?:
            • aalex_bom
              • Jan 2008
              • 214
              Like this?:
              [ATTACH=CONFIG]48174[/ATTACH]
              good idea mate
                • 22997
                SPC: small paper clip + a dot of two-part epoxy
                Then smooth out the ends with the Dremel. =^..^=
                • Oystercopy
                  • Oct 2009
                  • 623
                  I just repaired one by drilling a small hole, then putting a tiny screw in there. Held the charge sawtooth just fine, but machine still has the code.
                  I imagine I could possibly have other sawtooths bad on other drums, or other issues with the machine. I didn't see anywhere where there was a simulation to CLEAR the 970 code?
                  OC
