toshiba 3008ac
  • antone
    • Oct 2014
    • 344
    toshiba 3008ac
    Putting 1 orginal on Document feeder and glass 2 copies come out (help) crazy problem!
    Sent from my SM-N981U using Tapatalk
  • Vincent128
    • Sep 2015
    • 349
    Re: toshiba 3008ac
    If your charging by the click then I don't see the problem...We are going to need a little more information here as my ESP-O-Meter is low on angel tears.Like details on what happens to cause this, what modes (simple copy?...using the soft start button or hard?..regular copy mode ? what's on the display? what steps have you done to document the issue? What steps have you done at all....etc...
      • 23009
      Re: toshiba 3008ac
      Default number of copies set to "2"? Same image on both? =^..^=
      • tsbservice
        Field tech
        • 8020
        Re: toshiba 3008ac
        Somehow they managed to default copy mode to 2 sets?
        Reset to factory settings should clear it.
        • Rusty.Harris
          • Jan 2021
          • 633
          Re: toshiba 3008ac
          If somehow they managed to get it to default to 2 copies...I'd wipe/start over. Never know what might be jacked up.
          Is this a used/resold machine? If it is, best to do a decommission which will not wipe out the HDD, but, will wipe ANY
          user data, and set all of the non copy quality adjustments back to their default value. If you have it accessing the Toshiba
          ECC data cloud, just disconnect the network cable so it won't pull it from the cloud and you have to enter it again.
          The decommission will "fail" but it will still set everything back to default.
