Toshiba E-studio2010AC F101
  • jacem
    • May 2021
    • 4
    [Error Code] Toshiba E-studio2010AC F101
    Hello
    I am a beginner on your forum and thank you for your help
    My Toshiba printer shows the F101 error after I formatted the hard drive of it.
    can someone help me put it back in service with the firmware?
    The printer is almost new and did not display an error before
    A beginner's mistake ...
    Thank you
    Re: Toshiba E-studio2010AC F101
    Originally posted by jacem
    Hello
    Thank you
    why did you format the drive in the first place?
    do you have the service manual?
    • jacem
      • May 2021
      • 4
      Hello
      Thank you for your reply
      I initially had a CA00 error so I cleaned the whole machine.
      I then wanted to reset the machine to remove the error
      I was wrong in handling and effectively erased Svram and HDD
      PS : I dont have service manual for this one
        Hello
        You service a machine, being a noob without a service manual? Are you employed with a company or are you indy?
        Put a request in the 'manual request' forum.
        • jacem
          • May 2021
          • 4
          Hello
          yes I am independent and network technician, by wanting to troubleshoot I found myself in this situation
          Anyhow, thanks for your help
            • 8144
            How exactly did you erase the SVRAM and the HDD within the copier?
            1. Turn the power of the equipment OFF and check the
            connection of the HDD.
            - Connector and harness check
            - Check if the connector pins of the HDD are bent.
            - Check if HDD for other equipment is not installed.
            - Check if SRAM for other equipment is not installed.
            2. If the error still occurs after step 1, perform the following.
            - Perform HS-73 Firmware Assist mode -> Key
            Backup/Restore and check that each Key Status is
            "OK".
            - If not, recover the key (press [Key] and select the
            menu, and then press [Execute]).
            3. If the error still persists after step 2, perform the
            following.
            - Perform HS-73 Firmware Assist mode -> Format
            HDD, and then install "System software" (HS-49
            Firmware Update mode -> SYSTEM SOFTWARE
            (HD Data)).
            Notes:
            The following items will be deleted by HS-73
            Firmware Assist mode -> Format HDD.
            • Message Log
            • Job Log
            • Spool Data (Print, Email reception)
            • Template
            If F101_1 occurs with secure HDD or the error
            persists after performing step 3, perform step 3 after
            performing HS-74 HDD Assist mode -> Revert
            Factory Initial Status HDD.
            4. If the error persists even after step 3, replace the HDD.
            5. If the error persists even after step 4, replace the HDD
            harness.
            6. If the error persists even after step 5, replace the SYS
            board.
              • 22999
              When you get your HDD situation sorted out, the CA00 error is the lack of developer density patches or color registration patches. Based on what you've done so far, I'm going to recommend that you hire somebody who knows what they're doing. =^..^=
              • jacem
                • May 2021
                • 4
                Good morning all
                Thanks for your help
                I have formatted the hard drive of the machine correctly as instructed by SalesServiceGuy,
                the machine is now asking for OS firmware to proceed with the OS upgrade
                Do any of you have this one?
                thank you for helping me
