Toshiba e studio 457
  • sewa
    • Jun 2021
    • 20
    I change the upper heat roller very little (1mm) less than the original in diameter the copy image is perfect but it jams at exit sensor do you have any idea?
  • mojorolla
    The Wolf
    • 2583
    Re: Toshiba e studio 457
    If you mean a different diameter heat roll, then change it back. Probably not enough fuser nip to drive it properly to the exit section.
    • sewa
      • Jun 2021
      • 20
      But I can I just the alignment by 05 mode right?
      • sewa
        • Jun 2021
        • 20
        THANK YOU ! when i change the original one it works fine but U see the problem is the old one has Scratched/not able to fix the toner ,I search for the new one which I couldn't get in our region/Ethiopia/ so should i paint it with Teflon ? Non sticky spray or what shall I do ?
        • Oystercopy
          • Oct 2009
          • 623
          In every fuser, with a heat and pressure roller, the pressure roller is actually more important than the heat roller. When the PR loses flexibility and dries up/shrinks, there is nowhere for the toner to go but continually around the heat roller, which is what makes them fail. And, no, you cannot "coat" the aluminum roller with Teflon. At least, I've never heard of anyone doing that successfully.
          OC
            • 22997
            OC
            Years back there was an Indy in our area that painted on something that looked like metallic paint, but it was worse than useless. The toner stuck to it. I don't know if this was just an experiment or some kind of aftermarket product, but it was a dismal failure.
            • sewa
              • Jun 2021
              • 20
              OC
              Tank you gays!!! but I cover the scratched part with Teflon Tape Which is PETF and non sticky ,use for gas pipe lines ,it works fine for the time! but it will not last for long period.
              • mojorolla
                The Wolf
                • 2583
                Lol...gotta love it
                • Vincent128
                  • Sep 2015
                  • 346
                  Apparently Kapton tape is the new duct tape.
                  • tsbservice
                    Field tech
                    • 7963
                    It won't work. Stop using alternatives. No more problems
