Toshiba e studio 457(two)
  • sewa
    • Jun 2021
    • 20
    [Jamming] Toshiba e studio 457(two)
    after change opc drum the copy says E030 the service manual says it's some where jam in paper transport path but i have cheeked all options from output/input test 03-[fax][9][B] and[C] ,when i change exit sensor [B] will off(the high lighted will go) but I couldn't make the same for [C] the manual says "reverse sensor" but even if i change it nothing help?
    • 23009
    Re: Toshiba e studio 457(two)
    If you open the right door then swivel the transfer section left you'll see the reverse sensor flag. If you touch the flag it should return smartly. It's common for the return spring for the reverse sensor flag to become weak. Adding 1/2 additional wrap to the spring solves this issue.
    Much more rare, I have replaced that photointerrupter. =^..^=
    • sewa
      • Jun 2021
      • 20
      Much more rare, I have replaced that photo interrupter. =^..^=
      I try as you say in the exit sensor even I insert little piece of paper as a flag to block the light(open connection ) nothing its the same
      if I replace the photo interrupter 1- do you think it should be the same type? or can I use other model like cannon when I measure the voltage to exit sensor connector one Ground and two of them are -4.98(5V) and other sensors I measured are -3.3 V both .I was only trying to replace the exit sensor (the one found in the fixing assembly)this one .
      2. is it logical bord problem ?
      I will try the reverse sensor(the one above the fixing) and let you know !!! tanks for you sharing!!!
        • 23009
        If its the exit sensor, you may have left the sensor unplugged at one of three locations. Its very easy to do.
        I have no problem with trying other misc sensors to see if you can get it to change state.
          • 23009
          This is the reverse sensor, hanging slack:
            • 23009
            It looks like the whole Loire series uses C0-17839000 for the reverse sensor S10.
            It's a type BL sensor:
