Estudio 3505 saying duplex cover open
  • COPIERMAN
    • Jun 2009
    • 559
    i have check micro switch and push button switch both are good. i have manually push both in and still saying duplex cover open. I have not work on Toshiba copiers is there another switch i should be checking for.
    • 23010
    Re: Estudio 3505 saying duplex cover open
    It's not uncommon for those push switches to come apart when the door is slammed. The front of the switch looks normal, but the back unsnaps and can be found dangling from the wires. And the microscopic spring can be occasionally found inside the rear cover. It's the same switch used in many Toshiba machines.
    I've also seen the latch handle break, losing the hook at the front or rear. It's the same part on the eS4555C, just white instead of black plastic. =^..^=
    • Rusty.Harris
      • Jan 2021
      • 639
      Most likely what blackcat said, someone slammed the door and screwed up the door switch.
      But if that doesn't fix it, double check on the LVPS, F102. There should be a two pin connector
      near it. Both of those connections go to the door switch. If that fuse is open, it will trigger an
      open door switch.
      Haven't seen that in a LONG time, but my aging memory remembers an open door message and
      it was either a tech replaced the LVPS and didn't get the 2 pin connector seated properly, or something
      caused the fuse to blow.
        • 23010
        You can also get this indication if you lose the 24vdc at the power supply to the door switch. "Cover Open. Close the duplexer on the right." message alternates at 5 second intervals with "Ready". =^..^=
