3511 Fax board question
  • CopyDawg
    • Dec 2008
    • 74
    Is the fax board for an e-studio3511 the same as a fax board for the e-studio 230? Thanks in advance.
  • copytechman
    • Nov 2008
    • 969
    I don't believe they are. The 3511 uses the GD1200 fax option if I recall correctly and the 230 uses the GD1150 fax option.. You may want to absolutely verify it though.. mostly it's the mountings that r different! but the software and primary connector is different too IIRC..
    Regards!
    A.
    • atudorica
      • Oct 2007
      • 79
      checked the books
      e230 and e3511 use the same board GD-1150
