Toshiba e389cs Fuser error
    • 8410
    I have a e389cs/ Lexmark XM4140 that was displaying a fuser error. I replaced it with a used fuser from a known working e389cs model.
    The fuser error stopped being displayed but the copier was only printing about 25% of the width of the page.
    I made sure the fuser was correctly inserted and fastened tightly by the two thumb screws.
    Any ideas?
    Thanks,
  • Lunatech
    • Oct 2012
    • 224
    I am not saying the fuser could not cause the issue however it seems unlikely. Does it happen when printing from a computer the same as when copying? Is it different from the glass or the document feeder?
    • tsbservice
      Field tech
      • 8109
      Basically fusers are fixing what is already printed. You can stop it while printing and see where image loss is coming from.
        • 8410
        I was back onsite with the same tested, working fuser. I removed the toner/drum assembly, waste toner box and belt. I resassembled and made sure everything was latched tight.
        Presto! The copier works. I think a previous person worrking on the copier left open a latch that I did not see the first time.
