Toshiba estudio 166 print quality error
  • kgv1
    • Jan 2020
    • 6
    What could be the problem? Blade, developer? OPC is new.
  • tsbservice
    Field tech
    • 8010
    Re: Toshiba estudio 166 print quality error
    [ATTACH=CONFIG]50056[/ATTACH]
    Developer unit.
    • kgv1
      • Jan 2020
      • 6
      Developer unit.
      The complete developer unit or only developer (D2320) ?
      Possibly crown or contact fault?
        • 23007
        Did you try fresh paper? Moist paper can produce this effect.
        • kgv1
          • Jan 2020
          • 6
          Not paper, I tried with another paper.
          I'm thinking of charging.
          • kgv1
            • Jan 2020
            • 6
            here is another picture.
            To see that on the OPC there is toner, but on paper
            it doesn't cost him.
              • 8195
              [ATTACH=CONFIG]50058[/ATTACH]
              This copier was discontinued in June 2007 and is no longer supported by Toshiba Tec. Not for parts, consumables nor technical support.
              • Blizzoo
                • Aug 2013
                • 608
                Check transfer unit side contacts on the door
