HDD Problem
  • MacTavishLK
    • Nov 2020
    • 68
    [Electrical] HDD Problem
    Hello,
    How to connect SATA HDD to Toshiba e-Studio 256 copier?
    Thank you.
    Have a Nice Day.
    • 23008
    Re: HDD Problem
    You don't. The Toshiba e Studio 256 uses a Wipe Drive (Toshiba part number: G-00732000). =^..^=
    • MacTavishLK
      • Nov 2020
      • 68
      Re: HDD Problem
      Ok bro. But I saw a 256 copier using normal HDD. Therefore I turn on that copier in 4C mode. It shows me "SATA HDD". That copier is qorking normally. How is it possible?
      Thank you
      Have a Nice Day.
      • Rusty.Harris
        • Jan 2021
        • 631
        Re: HDD Problem
        I forget where the cutoff was, but some of the older machines came with a standard HDD, but, you could upgrade them to
        an ADI wipe drive. If it ever had a wipe drive, you can't downgrade it back to a standard drive. All Toshiba machines
        come with wipe drive now.
        • riyadh hossainbd
          • Dec 2015
          • 239
          Re: HDD Problem
          Thank you
          Have a Nice Day.
          All Toshiba es256 CND version is with normal hdd
          • MacTavishLK
            • Nov 2020
            • 68
            Re: HDD Problem
            ok bro but one copier technician in my country convert the Toshiba 256SE copier to normal HDD from wipe technology. how is it possible? If you all can help me to do that job please?
            Thank you so much
            have a Nice Day.
